  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
oh well as long as its ya arse and not ya balls ...... its so ungentleman like when a guy stands in front of ya and rearranges himself ..... unless he's ya other half.
Lee you surf net all day :) cant see that not being enjoyable unless you work with some pricks
thanks Paul .... i want 3 x www.skylinesaustralia.com and 2 x the headlight logo ones
Stock up least that way i wont have to wait so long next time!!
Originally posted by ReVN211
Niz, you get very bored of surfing the net. Especially when you use it for 40hrs a week. You can't find anything interesting to look at, half the time i sit on forums pressing the refresh button...
Welcome to my world ....... :uh-huh:
its better than bullshitting on my personal development plan tho. I mena what kinda question is How will i know if i have successfully achieved the tasks or undertaken the responsibilites well? and i have to ansewer that question for each task that i do. Its the same ansewer for every question ..... i know ive undertaken them well when people dont complain!!
i used to have quite a collection when i worked at a car dealership ..... none of the guys in my department had the programs to display it so it all got sent from the fleet manager to my email address under the heading "training" :)
yeah ive always hated reviews ..... no matter what you do its not enough for your boss anyway!! so i gave up trying and usually am a smart arse on stuff like this ......... what happened to just doing a job? why do we now have to have pyschoanalysis and go into depth with our bosses in time wasting meetings about how unhappy we are and they just tell us to change our attitude nothing is done about theres.
Guest
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
