  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
MrGTST - don't worry man - I'd way be in the same boat.. thats why I'm still thinking of if I should compete or not...
What say I bring down a few helmets and we see what happens?
Anyone got a plan/where to meet worked out? Maybe we should meet up south perth way and all head in together?
"Don't be soft, it's easy.." I've heard and followed that advice before.. hehe.... tends to hurt...
But seriously - I'll be running with a 14, maybe 13.8 second car.. nothing flash so I can't see how I'm going to do anything cept for hurt my stock clutch some more..
OK fair enough.... Another question.... Is there a BP nearby that sells BP Ultimate??? I ask because since I boosted my car really chews through the petrol quickly... To the extent I am concerned about getting there and back on one tank of fuel!!! The cruise to Yanchep should be interesting too!!!
I dunno about that... Maybe its my lead foot but I use about a quarter of a tank just going to Scarborough and back and I live near Warwick so its not very far at all.... Dare I even try to drive the 40 plus K's one way to the Motorplex drag and try to get home :P
I think you could put it down to my lead foot and the fact that I am still enjoying the novelty of high boost all the time.... even when its not needed.....
"I think I will go to the shops .... that will require high boost for sure" :P
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
