  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Brett,
They won't let you join Garage SPANK, it's an exlusive club. Ask Skyzerr if you can join the Red Devils, you can be there 2nd member:bahaha:
See'ya:burnout:
Is that right... Well I am sure if they let you in they would let anyone in... including the Hobo down on the street corner :D
Hehe .... Nah Troy has got some silly rule that you need to have a BURGANDY skyline to be part of the RED devils :D
my ex was 28 plus he was diabetic so often woke up to him convulsing on the bed next to me. 16 i was going out with a 22yr old. So yeah ive grew up real quick - in fact probably did htings around the wrong way :D
Yeah I know about them... but that does NOT mean I ever tried to join.... when I first joined up it was a big thing going around with each colour had their own "gang" :D
It was actually quite amusing as there were full discussion on what colours were better and why :D
Dan,
With the VF22 in then I'd be surprised if the gearbox last's too long. gtrken is currently working on building subaru's and most often when people increase the power the gearbox dies. He said that most people use the STi gearsets.
The Autronic for the WRX is very good, plus as it is a board replacement, looks like the original, so you can't be hassled by cops for it.
See'ya:burnout:
Guest
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
