  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Pauls yours is not bad ..... whatever the gel is its good it doesnt make your hair feel like cardboard. :P
Actually ive got a think about stiff cement hair ..... i dont use any styline products in mine ..... i own a bottle of mousse which i never use .... ive got this serum stuff that makes my hair soft n shiny and if i use that and blowdry my hair that is usually enough to keep my hair in shape.
so much talk about hair products ..... gone from turbos to blowdryers in the space of a page :) who said whoring was dead!
haha thanks boys your making me blush :(
Lee what pictures have you got - ive only got one so far :P
Yeah paul im having a few naughty days - cos i was sooo good leading up to PAS then im back to gym - and swimming now our pool all heated and clean :)
yeah imagine there would be a lot of funny looking men with sideburns at the hotrods show ..... bloody elvis impersonators :)
sounds good paul :P weather should be high 20's on weekend.
Nah i didn't go to the Hot Rod show, even though my inner Trev told me to go :bahaha:
I saw you there paul and should have said hi when Bretts car was on the dyno, but didn't get a chance to catch up with you after that as i had a busy schedule that day so was duck in have a look and leave :)
Niz seen a few pics on various sites, :P
Guest
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
