  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Kutter, All Joe's are odd;)
hahah shut up pauly, you can talk...
Dan, I love chopping people in my car, I come along side them then let the screamer pipe off in there ears:D
that can be mean so many things... lol:bahaha: :) you got enought room in the back?
Aidwin.. good to hear mate.. don't go getting toooooo much hp. I'm starting to get left behind.
Paul.. thinking of getting Ray to put in a Wolf. are map sensons and boost controller a pay extra option..? any idea of the cost.?
what do you reckon for a tune down at SST.. around the 4-500 mark..?
Joe, I don't mean :fart: in there ears:p
Aidwin, I'm glad that twin turbo magna didn't beat me in the dyno comp:D
hahah so people pass out cuz of smell or the sound? LOL
Twin Turbo magna? WOOT? COOL
RalliArt Twin Turbo MAGNA All Wheel Drive. that's awesome :)
Shan, The wolf is $1395, comes with a boost controller and MAP sensor. All you need to do is run a vacuum hose from the manifold to the ECU, the boost controller can run the stock ECU. Steve generally does the install and tune for $2000 for SAU members, if you do the install yourself it may be cheaper.
Aidwin, Funny is one way to put it;)
Guest
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
