  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by adam 32
id still want to go for a more recognised brand ie K&N, Apexi, Blitz etc its an expensive mistake
a $30 filter could cause over $2000 of damage. it happened to macka 6 months ago
Don't know what it is with you guys and pods.
Have had 2 xR's with em on , took em off , put std box back in with K+N .
NO difference at all, well none you would notice on the road.
Cheers
Ken
Originally posted by GTS-t VSPEC
Keep Macka away from the car, he's nothing but bad news:p
Ken,
True, but I can shear off a sump plug:p
See'ya:burnout:
Sad part was , it wasn't the sump plug , just the aftermarket insert.
* hmmm , can't even recognise a sump plug *:P
Cheers
Ken
Adam,
Your still getting a workshop to replace the valve right?
See'ya:burnout:
Hope it is the valve and not just a lump of carbon stuck under the seat.
Adam will be pissed off .
Cheers
Ken
yeh
i got a headshop lined up for next week
unless its something rediculously simple like a bolt stuck in there in which case tristan should know what hes doing. well have to wait and see, should be a bit of a learning experience nontheless
If it's a bolt stuck in there , you are gonna NEED a headshop cos the valve will be bent , seat scored and hope it hasn't peppered the piston.
Cheers
Ken
Guest
    • Yeah I've personally seen the RB26 pull 30 degrees of ignition timing out of the base timing map if the ECU detects a cold start, it nearly starts misfiring because of it around 2000 rpm and it feels like the engine has no power. I'm just surprised that modern OEM control strategies are actually trading off efficiency for in-cylinder emissions. I would expect something like aggressive EGR dilution + tumble generation valve use to improve EGR tolerance to reduce in-cylinder NOx + HC from crevice volume while also reducing throttling loss vs pulling out some timing if not knock-limited.
    • *** DATE CHANGE *** Date has been changed to Saturday 17th May. The time and location is still the same!
    • You're more than welcome to - looking forward to meeting you!!  The turnout depends on the event and location... Pizza Runs on a clear night can drag out a decent crowd!
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
