  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah just my cat .... she keeps bugging me .... its bedtime and shes annoyed im not going. ...... may sound weird but she's incredibly smart and knows the routine .... 10pm usually bedtime and she follows me in a snuggles up to me .... if im still up after 10pm she starts to hang around me and meow.
Lucky cat , two pussies in the bed..
* thinks*
I have used that one before.
I think....
Damn alschiemers
Cheers
Ken
Ken, Niz needs a new fuel pump, the Bosch 910 goes in tank right?
I think all the bosch pumps are a bit more than a drop in fit.
Usually require remaking of mount brackets and adaptors for the gauze pickup.
Niz
We are talking about pussies and you say the convo quality is going up??
Cheers
Ken
Ken, Yeah, don't worry I'll have help doing it, she'll kill me if I phuck her car up:D
yea but what a way to die...
btw , put a full stop between 411rwhp and more than Troy cos atm it sounds like you have 411 more than Troy which makes you about 687 or so total rwhp. hehe
Cheers
Ken
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
