  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Adrian .... please take the drift stuff off ya sig its annoying as Autos cant drift :D known fact
Wll got my covering letter done .... sugar coating plus .... all i gotta do after lunch is bring my resume up to date then its sent off :)
haha yeah good old monday ..... depression on the start of another working week.
wonder if theres any more Jenny Craig Chocolate Mousse left .... does Superman Pose "To the fridge"
burnt roof of mouth ..... again ....
See i look at it like this:
Auto box is good for 300rwhp .... now even a lot of the manuals in the club arent doing over that unless they've had a big arse turbo put in them..... which the average joe blow cant afford anyway.
So really ..... i can get my auto making the same amount of horsepower as a lot of the manuals in the club (high 200's) and really yor just as quick and its better for dragging ..... whales cant drift anyway so its not like you need a clutch for that ..... so i'll just save the $5000 needed to make it a manual (for no powergain or real purpose whatsoever) and go on a holiday :D
My 2c
Bad about the wisdom teeth - wanted to take mine out too but they are still in there.
Guest
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
