  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
don't worry dan i have no idea what jennay was on about b4 either, but i just acted like i did understand, just like what i do when people who can't speak english come into my work :cheers:
dan, for you speshal price $450
adrian :O
hahah this is hurten me more than its hurtin u boiiiii!
$450! :cheers: I have xmas coming up so I'll have to give it a miss
dont think anyone would be too impressed monday morning if I rock up with no presents and just a shining new wing
"LOOK at the wing, its ur present, its a gift from me to you, the ability to see it"
"GO AWAY Boi
Guest
