  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
works ok ...all fat barsteds .... thing is they didnt tell me but i work tommorrow then there office closes til the 5th! so im not getting as much work as first thought!
I got there .... parked under the tree in what seemed like a nice quiet street .... go out to check on my car at lunch and theres all these aboriginals n yobbos everywhere .... i see the childrens court is just across the road and there was a drug rehab centre which i parked my car in fron tof ;) not smart!
Guest
