  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
13 devil..... they dont latch after a while anyway .... my sony xplode one became like that .... so after a while they are unsuable .... just throw it in your glove box n lock it.
Guest
