  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
your one of the culprits mister .... i laugh cos everyone got upset when paul n i were whoring in one channel .... now thats closed and whatever thread is open everyone just whores in it.
whats in it for me to comeback to mirc :D
i just sit in my mums car Micko ..... or the pool ... otherwise no aircon .... but its all tiled here so its not too hot.
hey hey everyone
just got back from along day :D soo tied but before i got to sleep i have aproblem with my baby already for some reason the numbers of the dash (kms traveled ect) have stop moving and are stuck at 87 999 , it just happen 2day, i also had a problem with the turbo and boost it was running i found the little tube from the bleed value to pipe was broken and had fallen off thankgod i found that i knew it the boost was feeling to much for .5 bar hmmm
13 Devil ..... my odo has stopped too .... long time ago ... havent bothered to get it repaired .... it just means at sometime your odo clock has been wound back .... a lot of Skylines have the same deal.
To get it repaired you need to take dash instruments out and take it to a place like Asait in Welshpool.
Joe: I told you to go .... you think too much mister! So i take it you scored :D
Guest
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
