  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
later chaos
Jennay , give me a ring at Hyperdrive Motorsport ( which is 5 mins away from you in Malaga ).
Would say the boost line has dropped off your gauges and wiring the timer will be relatively easy ( bout in hour ) .
Don't get the TT connected onto the wrong wires and only problem can be the immobiliser but will check it out if you bring it round.
Cheers
Ken
Guest
