  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
don't lie riaz, you don't actually work man, you pimp out thailand whores to mexican midgets and bludge at your so called "day job"....
oh hang on, thats what I do ... *shrug*
okay i am back and alone again i c
doh well anyways i vegged all day long today
read a book mostly while at work
which is bad cos I got alot of work to do
terrible, just terrible.
yeah, it was a bit of a strange niche to get into, but now we've squeezed our way in, we're set for life man!
FOR LIFE! BWAHAHAHAHAH
anyhow, sorry I can't whore it up tonight, I gotta get some sleep so I can pretend to work hard @ my day job tomorrow.
Shall see you there.
Jason.
Oh, also, how do you like my cute new little duck avatar? I took the photo a couple of months ago @ my folks place .. random ducks came and stayed there for a week or so :(
Guest
