  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
oh really sad to hear Ken :) :grouphug:
yeah ive been finding it hard to sleep lately too
Thanks Lauren :grouphug: :cuddle: back
Been up for about 24hrs now and might wish you all g/night and try and get some sleep.
Hmm , the wavey smiley one seems to be gone
Cheers
Ken
Guest
