  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey paul, i better ask u this question as riaz, is alittle slow on the reply.
My S2 wing brake light is broken now the wiring is fine (check it all out current is flowing through it) so the LED lights r broken :D do u know wat i need 2 replace inside it for it 2 work again. Riaz said i just got 2 heat it up so te glue comes undone and i can pull it apart and fix it
Guest
