  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Twin PT52 Precision Turbo Engine Turbos will provide the Boost. Each Turbo is capable of making 600HP or 1000CFM of Air. Together the combination is good for at least 1200HP and/or 2000CFM of Air. The Turbos were selected to have a small nozzle diameter as well as a .85 AR Ratio. To allow these Turbos to spool up quickly in order to reduce the sensation of Turbo Lag.
:drooling:
mike if you read this before you go.
there is an arcade on murray street if you are walking down from pier street carpark
go past baskin and robbins
and then there is an asian grocery store
go past that and then next to it is an arcade. there is a shop in there called Aspec
go talk to franky and he will get you all the globes etc you need, he knows what goes in etc
no worries Mr Riceroni
peace
nah - soarer turbos use the same engines as the chasers. though with less beefy cams I think.
the old 1jz. little brother to the 2jz.
later model soarers came in a 2.5L tt, 3L6 n/a and the 4L v8s. now theyre purely v8s I think. but I have seen a twin turboed version of the new one in a video of some tuning shop in japland. forget which one....
Guest
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
    • After its dried out Penetrol is you friend to treat rust and seal up those seams
