  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey guys...im chasing a S-AFC and thinking of getting it from nengun. Has anyone used nengun before can tell me how long it takes for items to come from japjap? im a bit impatient as usual - decide one day that i want something and i need it asap :P Also, the approx postage costs for something that size?
mike oh my lordy man
I honestly wish that you would ask me stuff first sometimes to save yourself posting all over the forums etc when a quick sms or phonecall would answer your questions.
that rubber boot is split into rings after lots of years and has fallen into each other etc,
the spring itself is fine and the shock you cant really tell, but they are still factory standard.
the stock springs will go in with no dramas and then the car will ride high, check with wilkinson suspensions about getting another rubber boot, they should hopefully be very cheap,
NOTHING IS PHUCKED IN THE SUSPENSION apart from the super low and possibly cut springs which need changing with the stock ones i gave you.
me Ben???
R33 GTST & Z31 300ZX ..... but i was diving 33 of coarse .... both are my babies but i had to sacrifice ZX to my parents for the R33. :D Things i did to get Skyline!! otherwise it wouldve been a Supra TT funded by my ex.
Guest
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
