  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
You live 5mins from Galleria Mikey? you probably see my car around Morley a bit .... my gym is across the road from the Galleria. *mutters obscenties about speed bumps*
I got a job interview 7:45 tommorrow morning :)
i dont smile .... im a killer .... :)
nah i got a little red riding hood photo of me smiling and i think it looks ghey .... besides that expression is very much like my "race face"
Hey Glue
Guest
