  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
lol at cleaning ze pool .... adrian hasnt cleaned my pool in ages :) he's forgotten about my pool *sob*
might grab some nandos on the way to pauls after gym tonight ..... ive had a craving for it lately.
Car will be at gym 7:30 - 8:30 .... no writing filthy messages on it .... no touching it ..... or you will be a eunch! :) ... also if your lucky you'll see JMP's Yellow S15 there as well as he usually goes Thursday nights around same time.
Thinks back to last itme i earnt $8 an hour .... how did i survive?!
Guest
