Macka - I been once, 3 weeks after I got my car!!! On my last runs I started having the power probs I just fixed for the first time.
Don't reckon I got much out of the last session aside from the knowledge that I couldn't drive a greasy stick up a dog's you know what...
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
can't tell
the engine bay, can't isolate it seems to be plenum side but i can't tell for sure
Is it a new noise or just the fact that you are listening hard for the first time.
Cheers
Ken
oh yeah still no pressure at the radiator cap
Troy , stop being so paranoid and worrying about the worst case scenario.
As I said on the phone , it is probably the rad cap has lost pressure and allowing the water out of the overflow.
The murky colour is because you have probably boiled the water when it stopped and it's like giving the block a hot enema , all sorts of shit will come out.
Drive it home tonight , take it easy and don't use the aircond.
Get a new cap in the morning from Auto one , Marlows , Coventry's , whatever.
It's only a cap and the same as dozens of others.
Cheers
Ken
Cheers
Ken
fingers are crossed
driving like miss daisy all the way home and out to lumpy for the fuel pump
Ohh and drain the water , or get c red to do and stick some new coolant in.
The reason it boils is that without the cap pressure the water will boil at 100deg C
Your car should run normally at about 90 deg C and the 13 or 15 lb cap will raise the boiling point to about 120deg C.
this is why when you open the cap if it's in good nick after driving it , the water will suddenly boil , cos ya dropped the boiling point down to normal.
As yours has no pressure , it will boil easy.
Cheers
Ken
The hissing sound is probably normal pod filter induction or at the worst a vacuum line is off or split.
Just that you are looking and have suddenly heard what has been there all along.
Besides , a blown head gasket does not make a hissing noise , it causes the engine to run rough on startup ( as I said on the phone ) or blows water out of the radiator while it is running or a LOT of bubbles will appear ( some are normal )
Cheers
Ken
Originally posted by adam 32
when coolant says anti-boil - what does this actually raise the boiling point to?
it is the pressure in the radiator that stops most of the boiling.
Anti boil has an additive , like glycol or something , which raises the boiling point slightly , depending on the mix.
Cheers
ken
sounds good to me ken
i'll stop being a worry wart till the morning. :P
Good , can I close the online free mechanical w/shop and get back to whoring before pwpt60secf arrives ??:P
Cheers
Ken
Guest
    • Yea my question was really relating to having a big stall converter and it's interaction with that. Why would BMW not just put a 5500 stall converter in there stock then? Then the OEM car could just launch control hard.
    • If you fully flushed and filled it's probably good for 5 years. I would not push it any further than that. Generally speaking coolant is more by time than by mileage. Rust wants to happen whether you're driving it 50,000 km or 80,000 km.
    • Modern transmissions like the 8HP lock up as low as ~12 km/h. And they will stay locked even with full throttle in gear. Far, far cry from the days of 3/4/5 speed automatics when they only locked up on overdrive gears and even then only if you didn't put too much torque through it. Manual transmissions are pointless unless you personally enjoy shifting gears.
    • I read on YouTube that the neo has 2 bleeder valves? Can't see anything in the manual though
    • The only other time I changed it is when I noticed it had become discoloured after a few track days (it was .. yellowish). So I drained and refilled the rad.  I think most people are in this situation. It's not like the car ran any cooler after I changed the coolant either. I'm gonna go with "If it makes you feel better, change it!"
