  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
I hope you aren't disappointed then, she's reasonably quick compared to a stock one now:D
See'ya:burnout:
And so is he .
But I am sure pwpt60secf can rise to the occasion and be a gentleman.
( not )
Cheers
Ken
Originally posted by Sneeza
The light at the end of the tunnel??? wow - thanks for the well wishes hahaha :P
My fiance and I still do so many things seperatley - like SAU and SES  for me- he plays alot of sport and stuff and also does speedcar... so we're not in each others face 24/7
Well THATS gonna change once your married.
Don't get me wrong , marriage is a fine institution and I do wish you well.
Just make damn sure it is exactly what you want and not bow to parental pressure like my sisters did.
Cheers
Ken
I am a gentleman, but i won't take it easy in the car, even when you wimper and cry:bahaha:
See'ya:burnout:
Err paul that was supposed to be easy ON the car , not IN the car.
Cheers
Ken
I knew I shouldn't have said anything on here!!!! Ken - trust me its all good! We both have the same goals and which don't involve kids, sitting on the couch or gardening hahaha
By the way you're all welcome to come to the cermony
2pm 29th March St Patricks church fremantle (adelaide st)
why thankyou , I'm flattered but will be in Nannup on the Rally.
* hmm thinks she prolly knew that. j/k *
The no kids is a good idea. Gives you time , money and ability to do what you want , when you want.
Cheers
Ken
Guest
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
