  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Fuel cut defender is basically a device that sits on the signal from the AFM to the computer and stops the signal from saturating which would cause the boost cut to be hit. Boost cut on most Skylines is about 1.1bar, the fuel cut defender stops it from hitting boost cut, can be good if you have aftermarket turbo's.
I'm ignoring you Ken.
See'ya:burnout:
Natural progression items to mod ?
1. Exhaust, Cat back
2. Intake
3. Boost up (small)
4. Front Mount Intacoorla!
5. Exhaust, Dump and Front, and Cat.
6. Boost up more
At this point you can choose to start blowing intercooler pipes and working your turbo too hard like our buddy Hicks.
Or take the other A/M Turbo Approach, possibly bigger injectors and all the stuf that goes with it... this is when you start spending the BIG $$$ (something I'm not going to do)
-Kym.
Originally posted by Adrian_perth
strich9ine u big dawg
may i ask what mods you done to ur car?
to get that Fast and Furious Style 14.8?
adrian :D
http://www.hyperwa.com/sau/mycar.htm young adrian..
and the 14.8 isn't my fault it's running richer than your mum's pimp!
overfuelling BAD! safc coming soon.
Guest
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
