Originally posted by skyzerr33
this makes three padawan :D
I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd I am a star wars nerd .
PLEESE don't take me away , AHHHRGG the force....
Cheers
no nerd
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
hey ken - can you email the vid footage?
Sorry Sneeza , it's 13 meg and we tried last night a few times.
Burnt a CD . I am sure Paul can burn one for you if you PM him.
It's not much and you can't see my speedo ( thank god ) , but the trees and light poles starting moving backwards at a rapid rate. Hehehe.
Cos we weren't speeding so thats the only explanation I have.:D
Cheers
Ken
Originally posted by 33Spec2
on private roads rite!:D
Nah public roads but I'm not responsible for backward moving light poles.
That's the councils problem . I can't help it if they don't use enough concrete and the poles run off.Hahaha
Cheers
Ken
I don't think i have ever gone that fast in a car before hahaha
Yea must admit , we were up there.
Have gone faster in Targa on a road that was 1/3 as wide and over blind crests.
Thank goodness for pace notes and closed roads.
cheers
Ken
someone has 2 take me 4 a ride next time! someone who can drive better than me (pretty much everyone) !
Russ , going fast isn't the prob , it's the slowing down for the situation ( ie hazard , corner etc ) is what catches the novice or unwary.
You could have a run with me but I crash better than anybody I know.
Cheers
Ken
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
