its a little tiny thing hardly worth taking to mechanic to do - C-red have looked at it and said it needed replacing - my car apparently was doing a little song and dance splutter when they were pulling it into the workshop to have the suspension done - its only in low rev range it really plays up which means peak hour traffic to work n back is not very fun!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i am a tool haha do you know how long it took me to find the right size spanner to get the bloody nuts off the battery!! my dads shed is utter chaos cant find anything!
Instructions do help a blondie like me tho!!!!
yeah that means the spring tension ain't tight enough to hold the pressure in at low revs! and your symptoms sound right! you reckon the car is being very sluggish meaning the pressure is always being released because your spring tension isn't tight enough to hold pressure at all! lets just hope your BOV is adjustable! otherwise gonna have to buy another one!- i'll be on the look out for a re-circulative valve for ya niz!
adrian :P
yes sell them cost me $200 - so not a huge enough amount to push plus they didnt tell me til 4pm that arvo i needed it done so if they told me earlier i wouldve told them to go ahead and do it while the car was there.
i prefer to go shopping for these things myself anyway - cant afford anything for myself cos of the car so i might as make the most out of car retail therapy.
Thanks for the advice on what to go for Adrian - taken note of it.
yeah i like it to be stuffed before replacing too but then again i like to replace before it starts really affecting the driving of the car - and after 2 months - this is driving me insane - you sit at the lights and watch the revs surge up and down and think - is it going to stall nope going back up nope shuddering and going back down - werd!
yep thats exactly what happened to me with my mates r33 all he did was adjust the spring tension and it was back to normal! but again i will re-iterate MAKE SURE YOU DON"T ADJUST IT TOO TIGHT hehee otherwise you will get compressor surge! you will get that wikked chu chu chu noise but that is actually the noise of the excess air hitting the compressore blades! NOT GOOD!
adrian :P
where you been macka? long time no see hehehehe anyways i wanted to ask you sumfin dude! you know with the dump pipes is there really any difference in getting the sepreate wastegate pipe or not? coz i really interested in getting one of those dump/front combos off that batmbl dude! in the forsale section!
but only thing is that the dump isn't with a seprate pipe for wastegate!
adrian :P
Guest
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
