  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
You must have talked to the crew.
Yea , was a quick trip back from Busso.
Can't do much for him , they expect him to be gone in a couple of day's .
Either way he will never leave hospital.
Anyway , saw Mickos car at about 10.15 pm Friday night as I was leaving.
Who else went ?
Cheers
Ken
The job would have got easy anyway cos 2 of our crew went out on the first real gravel stage ( SS 3 )
Shane tipped on his side but will be going again tomorrow.
Adam rolled the car and will have a lot of work to fix it.
Cheers
Ken
Originally posted by GTS-t VSPEC
Yeah, we ended up going in to Nannup to the service area, found your camp and heard the news.
We saw your cars at the stages, they seemed to be doing OK.
See'ya:burnout:
Hopefully the boys did a good job servicing.
Would MUCH rather have been there than here atm.
Btw , Busselton to Joondalup Hospital in 2 hrs flat was a reasonable pace. If the cops caught me , I wasn't stopping but didn't see one. Hehe
Cheers
Ken
Alot of work and money:D
See'ya:burnout:
Yep but as head mine engineer , the money won't take long but I think the work might.
Rob just rang me and said it was messy. Every panel gone .
Cheers
Ken
Guest
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
    • Welcome (back) Gaston! Keep us up to date with the hunt!
