the boys have lifted the idle revs which has fixed the shuddering 85% theres definatley a problem there but no we dont know what it is - but as far as a quick fix this is working fairly well at the moment til i get it to tim later anyway - now ive got a spare $300 up my sleeve which is what i was going to spend on the BOV.
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i think i'll just stick with the team working on my car before - they seem to do a really good job even if i do have to pay a little extra for the privledge least accurate information is being given to me :mad:
cam
as for the show thing, yeah they have club prizes and one for a new clubs etc. and some of the guys were talking about it on the sunday so theres some interest.
two of the guys were there on the weekend.
pauls interested, i thank killer-t is i am with you and zan and shuto and possible the two who were there we could get 8 and possibly one of gtrkens GTR's
Cam,
Ken simply adjusted the idle solenoid, the rev's were too low, but we checked the BOV and it appeared to be working fine. Sounded like there may have been a small air ladk, but without some spray to find it we simple bandaged the problem till it went for it's next service:D
See'ya:burnout:
Originally posted by GTS-t VSPEC
Yeah we really need a GTR, and Ken's is a real racer. We might have to do all the work for him though, cause I can't imagine Ken wanting to spend all weekend at a show.
See'ya:burnout:
next big one is the western saloon which is usually near the end of october
Guest
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
    • The ECU does care - it runs the engine as two banks of 3 wrt O2 trimming. So you have to give it the right one. Um....look at the engine bay pictures in the GTR manual? I think you can make them out there. I think the physical wiring diagram might also help.... Actually, I just looked at the engine bay wiring diag. It clear shows the shapes of the connectors. I'd say that R means rear. According to the rest of that diagram, pin 2 of the R one turns up at terminal 55 of the ECU. Which is.....the rear one.
