  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ok then looks like we have our greasemonkey
hehe:P ill make a big effort to get everything organised tomorrow. theres a fair bit of work left, but its only a days-worth for someone who knows what theyre doing. if you can call that guy and ask him when his next available time is ill work around that. as i said, number 1 priority is fixing the car, nothing else matters at the moment
Originally posted by skyzerr33
so how many gags have u picked up so far?
ie the 92.9 - 94.5 switch even though they only kept it up for about an hour
umm none cause i haven't been listening... are they doing their typical bad jokes or something?
Guest
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
    • The ECU does care - it runs the engine as two banks of 3 wrt O2 trimming. So you have to give it the right one. Um....look at the engine bay pictures in the GTR manual? I think you can make them out there. I think the physical wiring diagram might also help.... Actually, I just looked at the engine bay wiring diag. It clear shows the shapes of the connectors. I'd say that R means rear. According to the rest of that diagram, pin 2 of the R one turns up at terminal 55 of the ECU. Which is.....the rear one.
