  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by zanda
I hear Paul can get a good deal on those!!
Might I suggest that the scheming of western salon-ness might begin on the cruise on the 11th?
Spoke to my associate from Silvia WA last night. theyre putting 15 cars in.
15?!?!?! jeezus.. we should get together a large contingent then i suggest... need some r34s too... :D
my mum says shes sending me over to an island or somewhere out of aus for my wedding so she doesnt have to invite my dads family *meow*
Well you can definately go holiday mode - barefoot in shorts and tank top in midland gate just like the locals.
hmmm they are suppose to be quieter when they are hot not louder i thought - yeah me and my mechanic went doing mini burnouts to try to get them hot enough to stop squeeling - didnt work but had fun :D
koh sumoi - i was suppose to go there haha with a friend because he gets flown over there by his fathers company to spend time with them - dad works on an offshore oil rig. But i kinda started going out with a guy and that was the end of that idea.
Originally posted by GTS-t VSPEC
15 cars is alot, I don't think we need to over do it, beside, most of those Silvias are plain and boring looking:D
See'ya:burnout:
true.. :D
i'm sure 8 or so lines next to each other will cause a decent stir... :(
Guest
    • The fuel pump bracket just slides straight up.  Below is a pic I stole off a site. But basically put hand in for fuel pump, wiggle it all about a bit while pulling up.
    • Went digging Duncan, there's another "item" that sits down under the plenum that the second pipe from the IACV goes down to. I believe that's the one that is apart of the cold start portion, and it then comes back up under the middle of the factory top plenum. I believe you will find it is unneeded on the forward facing plenum on Cheryl.   I just went digging further for some pics on the location of the one way check valve, and found something that confirms my thoughts from the first half of this point. I feel you can just block off that port that is coming down.     I can also confirm, the other line that you were thinking for vacuum that will just need a one way valve put into Cheryl is 100% correct too. The one way valve is normally screwed into the back of the factory inlet plenum.
    • You’re an absolute legend man. Cheers.
    • The rule of thumb for any GTR thats doing a single turbo conversion is..... seqy... and when i say seqy, i dont mean the pos PPG either. *flamesuit on*
    • The ECU does care - it runs the engine as two banks of 3 wrt O2 trimming. So you have to give it the right one. Um....look at the engine bay pictures in the GTR manual? I think you can make them out there. I think the physical wiring diagram might also help.... Actually, I just looked at the engine bay wiring diag. It clear shows the shapes of the connectors. I'd say that R means rear. According to the rest of that diagram, pin 2 of the R one turns up at terminal 55 of the ECU. Which is.....the rear one.
