joh21m Posted September 19, 2005 Share Posted September 19, 2005 Hi All, I recently broke a tie rod by hitting a gutter (i know i know), after i replaced the tie rod and got wheel alignment my steering doesnt have that nice tight feel. Its all loose and has little feedback... Can anyone tell me how to fix this or is it something i have to put up with??? Thanks, Joh Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/ Share on other sites More sharing options...
MerlinTheHapyPig Posted September 20, 2005 Share Posted September 20, 2005 take it back to whoever did the tie rod & wheel alignment Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1595255 Share on other sites More sharing options...
joh21m Posted September 20, 2005 Author Share Posted September 20, 2005 i changed the tie rod myself, found out the wheel has been bent back a little (something about caster). goin to get that sorted and hopefully it will come good... Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1596022 Share on other sites More sharing options...
joh21m Posted September 20, 2005 Author Share Posted September 20, 2005 oh another thing, wat aspects of driving does the caster of the wheel effect??? Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1596025 Share on other sites More sharing options...
predator Posted September 20, 2005 Share Posted September 20, 2005 turning.. check your caster rods to see if they are damaged also.. they are different to your tie rods Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1596030 Share on other sites More sharing options...
joh21m Posted September 20, 2005 Author Share Posted September 20, 2005 i see, so the loose steering must be because of the caster the bent wheel is creating... are they hard to change yourself (castor rod), cant be too much harder then the tie rod... Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1596048 Share on other sites More sharing options...
MerlinTheHapyPig Posted September 20, 2005 Share Posted September 20, 2005 in my experience. Running more castor gives steering a much more direct feel and a lot less vauge than stock, so maybe the castor rod has been bent slightly reducing the amount of castor. Post the wheel alignment results castor rods are heaps easier than tie rods 1 bolt goes through eye of the castor rod, and 2 nuts under the control arm, that's all. 17mm from memory on a 32 If you're replacing them, may as well get aftermarket adjustable pillowball castor rods. +9 degrees of castor feel sooo much better than stock. Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1596205 Share on other sites More sharing options...
Sydneykid Posted September 20, 2005 Share Posted September 20, 2005 If you're replacing them, may as well get aftermarket adjustable pillowball castor rods. +9 degrees of castor feel sooo much better than stock. <{POST_SNAPBACK}> I don't recommend using spherical bearings on a road car. Far too much NVH transmitted and they wear out real fast and then knock even more. The Jap tie rod manufactures tend to use unique spherical bearings, so you can't just pop into your local CBC Bearing shop and buy replacements. Even when you can, they cost more than the tie rod did in the first place. If you want/need more caster then adjustable bushes are a much better solution for a road car. cheers Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1596496 Share on other sites More sharing options...
Bl4cK32 Posted September 21, 2005 Share Posted September 21, 2005 How much caster does the Whiteline KCA331 kit add to an r32 SK? Ive got one here ready to go on, and was wondering what the factory setting is, and what it is after adding the kit. Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1596743 Share on other sites More sharing options...
Stu125 Posted September 21, 2005 Share Posted September 21, 2005 The offset bushes allow for about .75deg castor change Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1597021 Share on other sites More sharing options...
joh21m Posted September 21, 2005 Author Share Posted September 21, 2005 thanks for the reply guys, will check it out 2morrow. anyone else know y the wheel would sit further back, other then castor rod? By further back i mean towards the rear of the car... hope its just the castor rod and not the chassis bent... Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1598314 Share on other sites More sharing options...
MerlinTheHapyPig Posted September 22, 2005 Share Posted September 22, 2005 bent control arm? does the car drive straight? Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1598891 Share on other sites More sharing options...
joh21m Posted September 22, 2005 Author Share Posted September 22, 2005 no it doesnt drive straight, goes towards the left... Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1599005 Share on other sites More sharing options...
MerlinTheHapyPig Posted September 23, 2005 Share Posted September 23, 2005 post the results of the wheel algnment, they should give you a sheet which shoes how much camber/toe/castor you're running Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1603055 Share on other sites More sharing options...
Busky2k Posted September 23, 2005 Share Posted September 23, 2005 So whats the best way of gettin good amount of additional castor? Obviously bushes at 0.75 deg look pretty lame. I've heard of people redrilling the stock rods so they can be 'pushed' back further. How's that sound? Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1603282 Share on other sites More sharing options...
Duncan Posted September 23, 2005 Share Posted September 23, 2005 What is the standard non adjustable castor? I have seen 5o with the adjustable bushes Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1603325 Share on other sites More sharing options...
joh21m Posted September 24, 2005 Author Share Posted September 24, 2005 Ok heres the results of the alignment, if u need more info just tell me. Camber: -0deg05' (L), -1deg30' ® Toe: +0,4mm (L), +0,3mm ® Castor: +3deg36' (L), +5deg52' ® Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1604430 Share on other sites More sharing options...
joh21m Posted September 24, 2005 Author Share Posted September 24, 2005 haha ® = right, must me an auto format thing. for the castor setting that was the 'before' alignment setting, 'after' setting its 0? Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1604433 Share on other sites More sharing options...
joh21m Posted September 27, 2005 Author Share Posted September 27, 2005 hey merlin any input on the wheel alignment settings??? Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1609333 Share on other sites More sharing options...
MerlinTheHapyPig Posted September 28, 2005 Share Posted September 28, 2005 (edited) did you hit the front passenger side wheel? 0 degrees camber on left side is probably your culprit it means something is bent Edited September 28, 2005 by MerlinTheHapyPig Link to comment https://www.sau.com.au/forums/topic/88268-loose-feel-steering/#findComment-1609796 Share on other sites More sharing options...
