Clarian V-Net 275
Guest nismogtsx
Its a 275 series V-Net Amp....
Its a 2x75W RMS Amp...
Runs 2x250W Peak....
I have using it to run a single sub and it keeps blowing fuses and ive been told its cause im over powering it... So i bought a brand P Gold amp for $750 and now i need to sell the V-Net cause its no good for subs....
Its perfect for splits or rear 6x9's
Perfect to be used in stereo setups (not-bridged)
As its only 2 ohm stable...
Cost $299 brand new have recipt
Have spent $69 + $75 on repairs fixing it twice after i blew transistors... But its going now and comes with 12 months warranty from the repairer...
Selling $100 FIRM
Buyer pays delivery....
https://www.sau.com.au/forums/topic/8828-clarian-v-net-275/
Guest nismogtsx
I have no idea of cost...
I weigh's about 4-5kg's
So postage would be a bit....
It will have to go in a secure pack too...
NOTE: I will not COD as i have been burnt from my last 2 buyers. So for first timers with me i will require direct deposit / money order / cash....
Sorry just cant afford it anymore....
Pic 1
(Its as cheap as chips)
https://www.sau.com.au/forums/topic/8828-clarian-v-net-275/#findComment-130141
    • The way they do the test you would be very lucky to ever hit any cell that isn't aiming at 14.7 This was my result... Really not sure what's going on there!
    • I have a projecta one.  A proper trickle charger can be left attached 24x7, that's what the trickle bit is about.
    • With an electronic boost controller, there are settings available to limit overboost.
    • Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
    • Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off)   https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1   https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30   though these don't say anything about trickle charging, don't want it to overcharge the battery.
