Clarian V-Net 275
Guest nismogtsx
Its a 275 series V-Net Amp....
Its a 2x75W RMS Amp...
Runs 2x250W Peak....
I have using it to run a single sub and it keeps blowing fuses and ive been told its cause im over powering it... So i bought a brand P Gold amp for $750 and now i need to sell the V-Net cause its no good for subs....
Its perfect for splits or rear 6x9's
Perfect to be used in stereo setups (not-bridged)
As its only 2 ohm stable...
Cost $299 brand new have recipt
Have spent $69 + $75 on repairs fixing it twice after i blew transistors... But its going now and comes with 12 months warranty from the repairer...
Selling $100 FIRM
Buyer pays delivery....
https://www.sau.com.au/forums/topic/8828-clarian-v-net-275/
Guest nismogtsx
I have no idea of cost...
I weigh's about 4-5kg's
So postage would be a bit....
It will have to go in a secure pack too...
NOTE: I will not COD as i have been burnt from my last 2 buyers. So for first timers with me i will require direct deposit / money order / cash....
Sorry just cant afford it anymore....
Pic 1
(Its as cheap as chips)
https://www.sau.com.au/forums/topic/8828-clarian-v-net-275/#findComment-130141
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
