Timing And Tps Sensor Questions
Jolinator
 Share
Check the R32 Engine manual for max and min values as it should be in there. As for checking timing it doesn't matter whether you have the TPS connected or not.
What are you using to check the TPS voltage? A multimeter? Also you do know that to check the timing you generally have to get your hands an ignition lead which is a bit difficult on a coil on plug ignition system. I use a CONSULT diagnostic tool which allows me to check many of the readings that the ecu shows. If you lived in Perth I could show you....
checking tps with consult, also regarding tps being connected, yes it does matter, have you watched the timing change when you disconnect it? get a timing gun and try it
also regarding checking the timing, i am aware how to check it-
also i live in perth, haha
have a look in the apprentice thread, youll see my post
Edited by Jolinator
could u put the original question back in ur post? not much point in there being a search function if answers found dont have corresponding questions, the forums arent all about helping people all individually (etc)
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
