wondering how long the hdd will last with the usually stiff suspension in most skylines.
Most hard drives are pretty tough now a days. I've dropped a few and they still running fine. If you mount the hard drive sideways as opposed to flat, you'll lengthen the life of the hard drive too.
  • Replies 50
Yeah they are fairly tough, but I dont expect mine to last much more than a year though... HDD's definitely dont like to be moving when they're spinning! The price of laptop hard drives is cheap now anyway.. You can get a 60GB for $110!
The only way to counter this is with a flash hard drive, but they cost an arm, a leg, and your 1st born child's soul unfortunately.
Like, try $117,887 (yes, ONE HUNDRED AND ELEVEN THOUSAND!) for a Memtech 98GB Flash SATA Hard Drive! ;) Pretty silly when you remember that 4GB USB memory sticks are only $160 now! :(
That shouldnt be an issue!
Go to Mp3car.com and search "tweaks".. Find guides to disable services and crap the pc doesnt need etc... This will shave a lot of time off your boot up from cold.
I havent optimised mine yet, and its running at about 20 sec's boot resuming from Hibernate! By the time I get into the car, and wait for the LCD screen to slide out and up, the thing is pretty much booted! I think I have to look at a black screen for only 2-3 seconds! Youre using Hibernate and not shutting it down every time are you?
The Opus Power supply takes care of the hibernating and shutting down. I think its like when ignition is turned off - goto hibernate - then 15mins after shutdown. Alls I'm saying is that if windows boots quick (20 secs) from a standard hard drive. imagine how fast it'd run from flash memory.
Got some pics of your install Prim?
Ahh ok.. yeah booting from flash would be very quick!
I havent got pics at the moment.. I'll post some up tonight if I get a chance. The only thing you can see is the lilliput 7" motorised touchscreen in the dash. It's difficult to even see the laptop as it's mounted under the drivers seat on a docking station so i can remove it easily.
Which front end are you running?
Yeah thats what you would expect... The read rate and transfer rate are two different things. The transfer rate of USB2 is up to 480MBit/s... Where an average HDD is only about 120Mbit/s...
The READ rate (how quickly the drive can pick up data off the platter) on a HDD is usually between 30 and 70mbit/s...
So the read rate on the USB flash could be faster or slower... Im not too sure. But the Bus/transfer rate on USB2 flash disks is certainly higher. Whether or not thats the actual rate that data is read off the flash chips is another kettle of fish!
^^ This isnt gospel... it's just what I understand from the small amount of research i've done! :unsure:
I guess the best way to test it would be to copy a 100MB file from a USB2 > HDD, and then do the same file from a HDD > HDD. If the HDD>HDD test is faster, then you've got your answer!
There is a huge amount of issues regarding booting from USB2 disks though
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
