1 of the things that causes backfiring is running a rich a/f mixture. basicly unburnt fuel goes in the exhaust manfold where it explodes.
another cause is no cat, which muffles small pops and little backfires which you normally dont hear.
another is running a venting bov on a car with a sesnative afm. dunno about the lines but on my turbo laser, a vented bov made it back fire like nutz cause the computer would measure the air coming, and add the fuel needed, but this air would leave the bov so the a/f mixture would go rich, therfore cuasing a backfire.
i thinks thats all right
steve
Edited by PHATR32
Does this mean the ECU is not working correctly? Or is it the oxygen sensor?
My car has catlyst converter, and no bov so I guess it's because the fuel is exploding in the exhaust.
How can this be fixed? It's really annoying especially when you're giving it a bit to kick some ass.
Edited by harryg
Everyweek, I put about 40-42 litres of petrol and lasts me for 350-400Kms, so it's close to 10-11litres per 100Kms. I have never run the car down to the red light to get a more accurate fuel economy from a FULL tank.
However, the backfire is only occassional like once a week and normally happens when I shift from 2nd to 3rd around 4500 rpms.
Also, about 2months ago, I had full injector service done. But is used to backfire before that as well, so i don't think I can blame the mechanic.
someonestolecc has a good point too.
e.g the engines up at 6000rpm, injectors are pumping the fuel, then you suddenly let go of the tb and it snaps shut,
it takes a split second for the injector to stop the fuel flow, which results in a rich mixture, which causes the pop (or bang) (or flame)
steve
there's nothing wrong with a misfire here and there :D
as long as it doesnt backfire while u're accelerating, it's all good..
Thanks rukus, for clearing that up. And no the car never backfires while accelerating only on occassions while shifting.
Maybe I am letting the accelerator go a bit too quickly at high rpm as mentioned above.
Thanks to everyone for their contribution
  • 1 month later...
What about while ur idling at the lights? Every 10-15 seconds... and bad enough that it feels like someone's kicking u in the ass of ur pants lol. The whole car seems to jolt sideways.. That's what i have and it annoys me. Regardless of whether A/C is on or not (thought it might be related since it cuts in and out and makes the engine do stuff while idling).
faulty coilpacks or sparkplugs?
harryg, another tip - be quicker on your gearchanges...:(
Mine does it a fair bit too, expecially when the exhaust is good and hot. My car was complianced under SEVS, and therefore has a new cat - given how well it flows with the cat-back above 5000rpm, I'd be curious to know how "high-flow" that cat really is!
My gtr had an atmo bov, had to plumb it back for compliance since then it backfires on up changes only when the bov opens ie high boost
I think when the air decompresses it back flows through the afms causing rich mixture because the afms cant tell the reverse flow from forward. :D
Well just bought the car and during the test drive(s) the engine cut in and out from 4k to 5k rpm. They changed the plugs which they said were incorrect model and also had wrong gap and after testing again, it pulls hard and fast through that range now. So.. the plugs should be fine. @ coilpacks: they tested them and said they're fine too.
A mate reckons it's just the engine running rich to "help cool the turbo down" after a "spirited" drive. Not sure of the logic there.. and noone else seems to get this 'kick' during idle on a stock engine.. seems mostly to do with post BOV installation and other engine tinkering!
having no bov on a car that came with a plumback bov like all R32 and R33's, is like having an atmo venting bov.
your car still runs rich for a split second during gear changes or when you back off the throttle.
to fix it, fit a stock bov and plumb it back like it should be and the mixtures will be fine and no more backfire.
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
