  • Replies 100
Theres a pic of that dr30 at the auction yards in Japan just before Ben bought it with 16 watanabes on it. Do you mind me asking around what you paid for it Disco?
Like less than 10g?
That car appeared in 2 or 3 issues I think.
:D Ya can't get much more affordable rubber than 235 45 17", commodore sizes and cheaper than the last pair of 215 50 16" I bought in the same tire.
Theres nothing wrong with a bit of stretch :D
Fantasy performance manifold B)
Edited by DR JOSH
More than 9 less than 10 , yes been in a few magszine articles out here . I'm not sure what you call a "Watanabee" but mine have Rays Engineering stickers in them and are model specific ie right on the money offset wise . They had 205 55 fronts and 225 50 rear tyres which is better than wider fronts with wrong wheel offset .
I defy anyone to get more rubber on the road without lots of caster and just a smidge of negative camber . Turn in is far better than any strut Nissan I've ever driven . With the 205's it easily has more grip than the back which is the next area to mod provided the Bluebird power rack conversion dosen't get in the way .
If anyone wants a clean DR with a bit of history it's up for grabs , I want what I paid for it .
Cheers A .
Attached is a pic of some Watanabe's :O
Must have been Ben that changed them cause the next issue containing pics of your car, the Volks were fitted.
He also had it dynoed with 127kw atw with just the cat-back e xhaust fitted.
AFR's were 14.4:1 at idle and around 11.8:1 at full load :P
edit: Sorry bout hijacking ur thread Josh
Edited by slide247
The Vulks are composite (two piece) and look to have forged centres . Four piston calipers would fall in , theres that much room around the std calipers . Yeah sorry Josh , mine is same colour but all over with no lairy stencils . Do all these RSX's have black and red interior ?
Cheers A .
Just though I'd chuck up some photos of my beast before paint work, then I can put some up after.
The motor is currently in being machined.  B)
Josh,
Can you make a template of the mount plates for your strut brace and post it to P O Box N89 Campbelltown North NSW 2560.
Tah,
Dennis
Josh,
Tah,
Dennis
Ghost rider, I have a adjustable frount strut brace (cusco I think) in my DR but is only 2 bolt per strut top. Don't know if this is what you are looking for.
Cheers
Thats Neame's DR Adam, before he had an altercation in it...
My interior is black with red inserts, i think the RSX had the stripey interior whilst the RS just had the plain black/red interior..Correct me if im wrong!!
:P Ya can't get much more affordable rubber than 235 45 17", commodore sizes and cheaper than the last pair of 215 50 16" I bought in the same tire.
Affordable maybe, but what do you do with the extra 10 odd Kph the speedo is under reading with these 235/45 x 17 on board.
And do you know, the optimum tyre size for any R30 is 245/45 x 16 as they have the correct dynamic radius (same as 205/60 x 15) and they have the widest tread etc, etc, etc.
Why do anything else if it's just for show?
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
