Has anyone run dual exhaust on their cars at all? I am looking into running dual 60mm or 65mm exhaust due to my 80mm setup is scraping quite a bit due to my ride height.
Since the effective area is vital I can't just do two 40mm pipes to equal one 80mm pipe (2*40mm = 2513mm^2 vs 1*80mm = 5026mm^2), so two 60mm or 65mm pipes should work... just thought I'd point that out if anyone asked why so big for two... easily overlooked.
So what I was thinking is run one 80mm dump down to a Y-pipe that split into 2 60 or 65mm pipes all the way back... either exiting with two or converging back to one around the diff since it doesn't hit the ground due to the wheel.
Any experiences or ideas?
Another idea is to run oval... but it might be hard to find some pipe let alone a muffler.
https://www.sau.com.au/forums/topic/88373-dual-exhaust-ideas-80mm-scraping/
Dual is definitely quieter than the equiv single.
Bl4ck32's is amazingly quiet, still loud but not rude sounding and absolutely zero drone.
Dual = quiet. Another reason APS use it in their xr6 system.
Edited by Cubes
Very interesting everyone... does anyone have any sound files? My RS*R 3" kit is stupid loud the way it is... sounds good but it'll take the fillings in your teeth out if you have any. Sounds like I'm definitely going dual ...
Here's how mine sounds now... RS*R 3"
Edited by RBsileighty
Its well known amongst the v8 heads a twin 2.5" is quieter than a single 3.5" with the same high quality straight through mufflers.
sorry should have qualified that one -
i agree that a twin system with the same size mufflers will be less resonant and quieter, but a 3" aussie built system with decent sized mufflers can still keep the noise down, vs a twin system with smaller mufflers (or only rear 'mufflers' in ylwgtr2's case)
:O
Ronin09,
Exactly.. A 3" system. :O
3.5" systems are louder, noticably louder.
A 2 x 2.5" system is on par with a 3.5"-4" with regards to flow.
Thats what should be compared.
Bl4ck32's twin system has small mufflers on the rear, there is no droning and is only slightly louder than my 3" with a larger rear muffler and large center resonator.
I've heard a few 3.5" exhausts and to be honest they sound a little rude loud. I've now seen 2 twins on an rb30det and Tim Possinghams old RB25DET R33. Both looked to be the same exhaust, with regards to rear muffler size.
The Twin was not as rude loud.
That being said both of these twins have been on a single turbo, its quite possible twins on the gtr's twin turbo's react different.
Edited by Cubes
Thats a point I missed. :O
In all seriousness though, the size of your mufflers, I expected the car to be so damn loud it wasn't funny.
Its quieter than a dude around the corner that has a 2.0"-2.5" exhaust and a cannon on his NA Corolla. :)
well I'm getting a full twin system shortly....
63mm thin walled stainless, straight from each of the TRUST extended dumps.
it should make a little more power and also sound fantastic..
If anyone has sound files of duals... I'd love to hear them... however, ground clearance is point #1 for me since my Kei Office puts things really close to the ground. Not much could be louder than my 3" RS*R with no resonator and no cat so anything on dB limiting will be an improvement.
Yes its quieter now with its straight-through system, than with the old single 3" exhaust with the cat.
Oosh- ill try to get pics, but i aint got a camera :P
That'd be good but don't sweat it. :D
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
