hey guys ive decided to start a thread on my build up of the engine, and stuff on the stagea and saves people asking q's and ill post up heaps of pics as i go along :)
heres the info so far on what ive got:
Engine: RB26DETT
INTERNALS:
JUN 2.7L stroker kit
JUN forged crank
JUN forged connecting rods
JUN cosworth forged pistons
JUN oil pump
JUN head stud kit
JUN big end stud kit
JUN 272 degree/11.35mm lift cams
JUN adjustable cam gears
JUN titanium retainers
JUN heavy duty valve springs
Nismo bearings
HKS metal gasket kit
valve guides
Gates timing belt
n1 waterpump
INTAKE:
HKS T04Z (0.81) turbo
K&N Pod Filter (huge!!)
Trust stainless steel exhuast manifold
custom 3" aluminium intercooler piping
HKS 50mm external wastegate (vented to atmo :D )
EXHAUST:
4" dump pipe into 4" exhaust, to 3.5" after cat
4" magic cat converter
3.5" stainless steel mufflers x 2
FUEL SYSTEM:
sard 1000cc injectors
sard dual entry fuel rail
sard adjustable fuel pressure regulator
bosch 044 fuel pumps x 2
goss intank pumps x 2
Alloy surge tank
twin fuel lines from pumps to engine
DRIVELINE:
custom twin plate clutch
gtr 5 speed gearbox
GTR rear diff and axles
4.3 diff ratios
SUSPENSION:
bilstein shocks
whiteline springs
whiteline/arc swaybars
BRAKES:
R34 gtr v spec front 4 spot brembo calipers
DBA 328mm alloy hat slotted rotors
R32 GTR rear 2 spot calipers
DBA 300mm slotted rotors
brembo front brake pads
bendix ultimate rear pads
stainless steel braided brake lines
OTHER ENGINE BITS:
Autronics SMC ecu
Autronics CDI ignition amplifier
MSD coilpacks
nismo engine mounts
nismo gearbox mount
oil cooler
custom 9L baffled sump
need to get a 100mm thick cooler blitz or apexi or something similiar, and thats pretty much all i need to get now :)
engine is at the machine shop at the moment and hoping to get block back within 3 weeks or so and the head is machined for the cams and porting is being done as we speak, the HKS t04Z turbo is ordered from japan and waiting on exact price from HKS :)
heres a few pics of the car at the moment and a test fit of the brembo r34 calipers and dba alloy rotors which luckily just fit behind my rims :D
and i been hiding all the headlight wiring harnesses and all the wires that run along between headlights and battery and headlights and air box on the other side, i took a few pics with the wiring gone and if u checkout your own stagea's they are full of wires usually :P
and heres the dba 328 mm rotor compared to the stock stagea front rotor :O
and ill show i few pics of before it had the motor taken out :)
ill update as i go in here rather than posting heaps of different threads :)]
cheers
Brad
Edited by StageZilla
https://www.sau.com.au/forums/topic/88412-updates-on-the-jun-27l-staj-build/
What did you have to do to convert the rear end to GTR?
Is it just a rear GTR diff and axle stubs? They all bolt in perfect etc? New driveshaft?
I mean, the power i will chase in the end, id like to at least be prepared as youve said stagea axles are tiny.. :D
hey alex its not as simple as first thought :)
the easy bit...
gtr diff housing and stagea housing r identical size, except stagea one has mounting points for attessa pumps and gtr one doesnt so i put the gtr diff internals in the stagea diff housing and therefore the same abs sensors were in also as the gtr ones r different, the rear diff plate on the gtr diff is alot bigger and shiny ally fins where as the stagea one is flat and black, gtr one bolts on ok but the fins hit on the rear cradle not allowing to pull hard up when bolting up, so we bent the end piece of the crossmember lip like 2-3mm and its clear by a few mm, which is fine and totally unnoticable :O
hubs and brakes fit str8 on with the change of two of the bushes, easy as :)
stagea tailshaft bolts str8 on as normal :)
axles r two different lengths (drivers side is longer than passenger side), which is something i didn't realise for a while, and i tried the gtr long axle on the short side and it was too short, and then i got a gts4 axle and tried the long side on the short side of my car and it fit perfect, so i got another gts4 one and thought it would fit (thinking they were the same length :D ) and it was wayyyyy short, like 70mm i think, so we cut up one of the gtr ends and welded on an extension piece on the the main bit that bolts onto the diff flange, and its lasted for abit of absolute thrashing and hard launches etc with 360rwhp but i dont know how its gonna take 600hp+ :lol:
time will tell :P
Ok,
So for realistic purposes, i may be better off to get some custom axles machined up by someone in just thicker diameter metal and stronger alloy?
Add a NISMO GT PRO LSD to the mix and that should mean overall improved strength i suppose...
Do you have any info on how the ATESSA would hold up with increased power? What problems can arise and what are the consiquences of the ATESSA going?
Ok,
thanks gts evolution, i got em for a bargain price, thanks to a champ :)
and alex im not sure on the attessa, but its the same as the gtr one so i cant see any problems but thats what ive said about this whole conversion from rb25-26 etc etc and look its been on the road 3 weeks in 10 months :D
patience is the key B)
What did you use to paint the rear caliper?  Did you do it yourself, or is it a pro job?  I was always under the impression it wasn't a good idea to spray the inside near the piston.
Its going to be a damn fast volvo ;)
painted them at home with that anodizing paint, but u gotta buy an undercoat first so it sticks, its about $40 for the colour and the primer which is ok, it looks awesome for a spray can job :)
theres a thread in the tutorial section which explains details about the paint and how to do it etc :)
heres the link... http://www.skylinesaustralia.com/forums/in...+brake+calipers
i cant wait to drive it dont you worry :D
i love volvos ;)
cheers
Brad
How is the build going?
engine is still at the machine shop and the shop is waiting on jun specs for clearances etc which is taking for bloody ever.
turbo i am waiting for, and bov waiting, and suspension waiting, need oil cooler, and head needs to be ported and assembly of the engine then :)
i just cant bloody wait hehe :cheers:
  • 3 weeks later...
well finally some development in the build, and i picked up the freshly machined block yesterday and the head is machined for the 270/11.35mm lift cams but it still needs a freshen up and port and polish.
the day prior to that i picked up my HKS T04Z Turbo and its got through customs without and taxes haha, and it weighs a bloody tonne, lucky lucky i reckon :)
so with the block ready i just need to sort the head and then i need to get the JUN stroker kit instructions translated for torque specs and clearances etc.
assembly is not for away and im still searching for a 100mm thick jap intercooler, might get an ARE one, or a brand new blitz one if i have too.
ive got the n1 water pump and im wondering how that is with abit of street driving? because im going to be revving to over 10k so a stock water pump wont cut it?
heres a pic of the turbo and one with it next to a stock gtr turbo.
cheers
Brad
Considering you wont be needing your std turbine, want to give it to me at a bargain price so that i can get it rebuilt for my stagea?
I know its probably in good condition anyway, but im looking for a an any condition one to rebuild
its a standard rb26 turbo :) not much use on a 25, and i sold em off anyways :)
  • 3 months later...
The full build up thread is over here: http://www.skylinesaustralia.com/forums/in...showtopic=98086
That is so stupid, why the hell didnt they just unban StageZilla?
Politics, really gets in the way sometimes.
I wondered why the name change happened. What's the background to this for those of us obviously not in the know?
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
