k i wanna know if thats at all possible, if so how much work is required to do it??? to much to even bother with??? and if your asking yourself why the f**k would you want to, my answer is to be different, and to prove the potential of the RB25 :D
https://www.sau.com.au/forums/topic/88422-is-this-possible/
the bulk of the 26 parts dont match up on purpose so you have to do some custom work yourself to make it all fit. for the $ spent and gains you would probably be better off buying an aftermarket single turbo kit with ball bearings and steel wheel than two stocker gtr turbos with ceramic wheels which are probably 8 years old. youd need a twin t28 manifold, two turbo's, two airflow meters, airpods or airbox twin dumps and front pipes to match and then goto single 3" cat, would also need twin oil and water lines made up
https://www.sau.com.au/forums/topic/88422-is-this-possible/#findComment-1596127
you guys haven't peered into SkylineGoeff's GTSt's engine bay have you and seen the twin N1 turbo's hanging off the RB25DET. Shame the engine carked it... would have been fun to see it going properly.
https://www.sau.com.au/forums/topic/88422-is-this-possible/#findComment-1596158
Guest
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
