i have a jaycar boost controller
jaycar fuel adjuster
and hand controller
and cord
these all cost over 250 in kit form
these have being put toghrter and tested all good
these i will sell for 190 firm pm me
Edited by teazn_r33
and hand controller
and cord
That is a cheap price, there is at least a full days labour in making up the kits and that's if you are experienced at making up electronic kits and have the right tools.
For more information on these great kits pop over to the Stagea section and have a look at the Jaycar DFA and IEBC thread. My Stagea achieved a 30% increase in power from tuning with these and that's with zero mechanical mods.
Hope you sell them, I want to see other peoples results.
:O cheers :)
Hey thats a great price but they dont cost over $250.
I have built the three kits aswell, took me a few days. Good luck with the sale.
DIGITAL FUEL ADJUSTER RRP $79.95
HAND CONTROLLER FOR DIGITAL ADJUSTERS $59.95
INDEPENDENT ELECTRONIC BOOST CONTROLLER RRP $79.95
RS232 Connecting Cable Computer Lead - 1.8mt RRP $8.35
sorry plus i forgot to mention a apexi solinoid from a boost controller i use to have better than the standard ones
so yes over 250 worth sorry
190 must go today or tomorro
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
