Hi.
I plan to import a Stock Nissan Skyline R33 RB25DET. Octane 98 is not available in my area. Would it be ok to use Octane 95 after I reset the stock ECU? Is the stock ECU hard map to using only Octane 100? Or, since I can not get Octane 98, I should import a Nissan Skyline R33 RB25DE instead of the turbo? I do not plan to race or modify the car. Also, what is the difference between ping and knocking? On my old car, my knock sensor was not working properly, so the dealer diagnosis it because the check engine light was on, so I had it replaced.
Knocking and pining are the same thing, differently worded. I beleive tuning the car would allow it to run on lower octane fuel, but you'd want to be even more sure that the air temps are cool especially on hotter days.
If you are going to mod, and run more boost, the summer air could cause some pinging if you don't run an appropriate intercooler.
That's my input, but i'm sure that more veteran-style users will give you better info. =-]
You could always run octane booster but that could get a tad expensive puting a bottle in every time u fill up.. lol
95 should be ok aslong as u run stock boost and get the car tuned correctly.. because fuel quality always differs..
I run 95ron full time as its the highest available here. I'd say fuel up with 95, reset the ecu & u should be fine. Stock ecu is not tunable... but, its clever enough to retard the timing if it detects detonation.
don't be ignorant people...
your options are:
1) don't get a car if you can't maintain it
2) if you MUST have it, then either get the timing retarded or the ECU re-written to accomodate the different fuel
i ask you this question... would you put deasil in, if it were the only fuel available in your area?
    • Por qué no los dos? Body colour red with black stripes down centre, onto bonnet and bootlid.
    • From my bolts, standard M8 with 1.25mm thread pitch (M8x1.25mm).    Length is 19mm under the head and has a captive 18mm OD flat washer.   20mm length from a bolt shop is what you'll be able to get.   Make sure they're zinc plated.    If you're concerned about strength, grade 8.8 will be more than enough. Original PN is 01121-04971.  Now discontinued according to Amayama but that's because it's one of the parts that's been captured by the Heritage program, which explains the ridiculous price.   New PN is 01121-RHR20: https://nismodirect.com/nismo-heritage-bolt-pin-hinge-hood-bnr32-nissan-skyline-gt-r-01121-rhr20-01121-04971/ About AUD33 converted from Yen in the above link but that's just one example. Interesting that the hinge-to-body bolts are still available non-heritage.....PN 08116-8161G around $2 each (amayama).    Same thread but 16mm long.
    • Well, if that filter was impeding fluid flow, then it could have similar effects to faulty solenoids. The TCU will register a fault when it does something (ie, changes the state of a solenoid) and does not detect the required result. If there are other causes that can make the same lack of result, then they will be indistinguishable to the expected cause for which the TCU has a code.
    • Yellowjackets, red ones, blue ones (other than Splitfire) have all been demonstrated to be unreliable on turbo engines. That unreliability can be anything from outright failure (ie, 4 out of a set of 6 working out of the box) to just not being strong enough for the task, on a boosted engine. Not enough of us care about NA engines to know whether that unreliability is an issue for the undemanding needs of an NA RB20. I should think though that the DIS-008 should fit the 20. There's not really any reason for the head/coil mounting area to be any different on those 2 Neos. I wouldn't be buying Splitfires, or any other old tech coilpack, for a car in this day and age though. I would buy modern pencil coils and do what needs to be done to adapt them to the loom. That's relatively trivial these days, with numerous kits for fitting R35, or Audi, or Yaris/Corolla coils.
    • Keen to see how much work is needed to get an abandoned Skyline going. My R32 has been sitting idle for three years or so but finally got some time to get it going again. (Also lurking SAU and trying to hit 10 posts so I can start my own intro thread with pics)
