I had a Toshi chip put in & it made decent difference between 3800-7000. Felt stronger & more responsive. It was $250 for the chip fitted to your ECU or $350 to by a chipped ECU outright. What you get out of it depends on what mods you have to an extent. Mine's just got an RB25 turbo, 3in turbo back exhaust, filter & R33 GTR fuel pump.
Can anyone recomend a good place in Sydney that can do a rom tune on a RB20?
Im also keen to get some tuning done. Not that i dont trust toshi, and ive read the reviews in his posts many times but it just worries me that he doesnt do any tuning on the dyno or road...... I know you have to inform him of mods you've made to your car but each mods will change depending on the health of the individual engine and what products you use etc...
also i take it that toshi takes of the speed and boost limiter??? does anyone know what the factory boost limit is????
confused.
:D
Toshi will make a chip based on the info you give him. Then he hooks up his laptop & a Lambda sensor to your car for a road test. Checks boost/AFR/ingnition maps you have. Then he'll demonstate the chip he's made by putting his ECU with your modded chip in and doing the same test.
With the chipped ECU he can then use the laptop as per a fully programmable ECU to adjust ignition & fuel maps until you are happy with it. He can then make a new chip to suit if required. It took a couple hours all up for me.
He has all the equipment to perform this on the road but I'm sure if you wanted to book some dyno time instead he'd be happy to. & yes speed & boost cuts are removed.
Best to talk to him about it on yuna at tpg.com.au
He is japanese so his english can take some getting used to on email/phone though... :D
Toshi will make a chip based on the info you give him. Then he hooks up his laptop & a Lambda sensor to your car for a road test. Checks boost/AFR/ingnition maps you have. Then he'll demonstate the chip he's made by putting his ECU with your modded chip in and doing the same test......... etc
Thanks for clearing that up!!!!
when i get my front mount its on!!!!!
I haven't had it dynoed since but he seemed to think it had similar 'seat of the pants' feel to 170rwkw R32's he'd been in. Not much really but my car is pretty long in the tooth both in km's & years so thats fine by me.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
