R33 S2 Stolen
Mid_Nite_R33
 Share
  • Replies 134
sorry to hear about it dude, im in the Elsternwick area every now and then and wouldnt of thought u could get ur car stolen in a place like that.
heres another reason y its worth getting full insurance, what type of alarm system did u have and was the car parked outside your house?
Hey,
My car had no front mount, yea I think I know which car you're talking about, he has 18 inch advantek type rims and an after market intercooler on it, it is a rare one. The owner of that car knows my car, he's seen it at Noble park maccas. So i dont think that was my car.
Why dont u go down to Noble Maccas on a Friday night with a few mates and ask some questions, without giving away that ur the owner of the stolen car. Say u wanna buy some stolen rims or something. Theres a good chance that the people who stole ur car also deal in other stolen goods.
Also, make a list of people who knew your car didnt have an alarm. I know it sounds cynical but really u never know what kind of friends u really have.
My mate reckons he knows some guys that hang around the dandenong area and that are into stealing cars. If u want i can make enquiries for you, though i dont think that they would really tell him. Worth a try i guess.
Good luck man, and good luck with dealing with the cops. Hope u find ur car real soon
Edited by Taso84
wots da cops doin now?? r dey even bothered?? dose f#@$!% up c%#$!...cant rely on em...i had someone try ta jam open ma door a month or 2 back...totally screwed da door lock...dats when it hit me dat people still jack gts-t's...put in a security system right away...
I think they are well aware that the chances of it being anywhere visible (unless its totally gutted burnt or worse) are slim to nil.
unfortunately (or fortunately perhaps) a stolen car isnt their number 1 priority...
 Share
    • Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
