just wondering what could cause a GTR to start running unlimited boost.
(The boost restrictor has been removed)
i have been told that removing the pipes that go to the wastegate actuators and blocking off the hoses will cause the turbos to only run about 8PSI assuming the actuators are fine.
basically i want to limit boost to around 12 psi
https://www.sau.com.au/forums/topic/88532-why-was-my-gtr-on-unlimited-boost/
  • Replies 74
should be right as the actuator wont have any pressure from the line to help hold it closed is it would only be relying on the spring pressure to hold the wastegate closed.
( I could be wrong though I'm not very smart)
either that or swap hoses with some care 26 owner this is probably the easier option so you dont run the risk of blowing your motor
you should get a boost controller?
why mess with dodgy hack ups on 15 year old+ turbo's with cermaic wheels. just asking for it to go bang. if you unplug the pressure lines to the stock actuators then the spring will never move, thus the gate will never open so it will keep winding up pressure for ever
if you disconnect the actuators line you will get max boost the actuators a able to hold on the std turbo that around 19 psi (way to much for the std turbo)
if you put a direct line from boost to actuators you will get the minium the boost the actuators will run ~7 or 8 psi (i think not sure on this spring set)
a bleed valve or boost controller just bleeds off a some of the boost pressure being supplied to the actuators to govern the pressure between these to points
pete
ps buy a $99 dollar turbo smart bleed valve and you will be able to set your boost fine, just keep the lines as short as posible to reduce piking.
well the motor is getting put in the car today after a rebuild with some tastey parts..
before 2 pistons fried it was (for some reason) running unlimited boost... it went to around 12psi at only 2500rpm!
i want to limit the boost as much as possible.. and i dont know why it was running unlimited.
this will be for the run in process then i will be getting a power FC.
i want it limited to around 7PSI
like i said run a boost line direct to the actuators with give you minium boost (to what the turbos are preset to)
It appears you have disconnected the boost pressure line from the wastegate itself - is this correct? If so, where does the wastegate get a signal of what boost has been generated?
The boost signal forces the wastegate open when a preset boost level - enough to overcome the spring - is genarated. The spring actually holds the wastegate SHUT. So without a boost signal, the wastgate stays shut, and boost keeps on building.
Whoever told you you could remove the wastegate lines should be sent the bill for the repairs to your engine.
nah,
what happened was, i heard a noise that sounded like an exhaust gasket was gone (statrted to sound like a truck)
so i took off a few pipes to see if i could see any part of the gasket around the turbo had blown off. i may have taken i hose off the wastegate, but it was put back on and everything was normal again before i started the car.
after this.. for some reason it was on unlimited boost :blink:
i checked all the hoses around the wastegate.. i saw one was corroded.. i changed it with a new one.. still made no difference...
i have now been told that disconnecting the wastegate hoses will cause it to run off the spring and boost will limit to around 8psi.. however i agree with you, i think it would cause it to run unlimited.
could a wastegate be stuck... stuffed actuator?
Q: Why Was My Gtr On Unlimited Boost?
A: you messed around with a car you don't know much about and as a result popped your motor.
I can't beleive you are "helping the builder out a lot with the build" when you can't understand the simple basics of boost control mate. it's not that complex.
it's not a stuffed actuator mate. you f**ked up the pressure feed to the wastegate actuators. simple.
sorry if i sound rude but it bugs me that people keep blowing up cars through ignorance.
Holy shit.
Who ever told you this, should NEVER EVER EVER EVER be allowed to drive a turbo'd car. EVER.
arhhhh..
the lines were fine.. they were not leaking, they were connected.. and it was still running unlimited boost.
so your saying.. if this hose was taken off... then put back on 5 mins later exactly the same way, it will f**k it up?
arhhhh..
this might be my great detectives brain at work but lets look at the situation again shall we:
car is running normal boost
you disturb the pressure feed hoses
you put them back
car is now running unlimited boost
nothing else major has been done except you disturbing the pressure feed hoses
my conclusion is quite simple, you didn't put them back correctly. If you beleive anything else you are dreaming.
i know how to take off a hose and put it back on. Im 100% sure it was put back on correctly as it was tripple checked.
the guys with my car said a lot of the hoses on the zaust side were corroded. but i was making sure that that was actually the problem before i put the original actuators back in.
i am not saying that while i was doing something the pipes corroded all of a sudden, obviosly i must have moved something and one of the corroded pipes split.
you seem prety certain the actuators are fine, so i will see how it goes with the new hoses.
well actually,
this will bring the boost back to around 1bar as the restrictor had been removed before i got it..
i think a zip tie around the hose to the boost solinoid would restrict it
Edited by druzilla32
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
