standard boost when it is disconnected because it has a bleed on the vaccuum line that feeds from the engine after the solenoid that prevents it from overboosting if the solenoid fails/disconnects, i had to install my boost controller on the turbo side of my engine after the solenoid and the vaccuum feed, just before the wastegates. i think i remember reading the t-piece that feeds the line is between the head and the firewall...round the back of the engine...
  • Replies 74
Hey this is a great thread and should be stickied.
I have *never* seen so many clear explainations of how boost is controlled it is great.
A must read for all turbo n00bs.
Wrong. You disconnect the stock solenoid and leave the pipes open it will FREE BOOST.
It's simple.
There is a T under the back of the plenum. It T's 1 to the wastegates, 1 to the solenoid. Now if the solenoid failed.. my guess would be it would stay closed which would give you stock boost.
You remove the solenoid however you are now BLEEDING air from the wastegates, and we all know what you get when you bleed air away from them.. a boost increase.
Now the other end of the solenoid simply bleeds air back to the intake pipe. (for emissions etc)
To install a boost controller in the stock position, you need to block the pipe right at the rear of the plenum (the T), and run a new pipe from where it was connected to the plenum. This is the pressure feed. Now the stock line that goes to the solenoid has a direct connection to the wastegates (because you have blocked of the T into the plenum). This can be checked by putting some air down the line and hearing the wastegates open and close.
You block the feed to the intake pipe.
I think people need to get a engine up on a stand, follow all the pipes and make a drawing or something so they can understand how it's all linked.
i may be wrong but even i have disconnected it completely and run stock boost...
okay, is there any one way valves? on it maybe? basically it cops a feed of vaccuum wether you have the solenoid on or not, maybe it is the restrictor in the line causing it enough restriction to only produce stock boost when the solenoid is disconencted?
Edited by oRiCLe
Hi, interesting post great information. I have a few questions I would like answers though.
My gtr had the restrictor olives removed before I purchased the car. I was given the two olives in a bag. I know one goes in the hose with the yellow stripe near the boost control solenoide, where does the other go?
Why have people said you can't fit the olives back in and to purchase another hose? I'm sure it will be tight but if you're careful and use say, a dril bit or something to make sure the hole in the olive is clear and does not go in sideways and block the pipe, should be ok. I haven't tried it yet, just a thought.
I'm thinking of reducing the boost as I noticed there was some boost creap on a recent dyno run. With the information I've read in these posts, I will be checking the condition of the wastegate actuator control lines for leaks etc. Maybe one of the actuators or wastegates is being restricted and therefore the turbos are making more boost than 1 bar. I'm running standard ceramic turbos!
Thanks guys
Hmm this is possible.. with the stock restrictor in there and the solenoid removed it may not bleed enough out to cause unlimited boost.. it would be more than just having a pure pressure feed though.
Thats a thought.
Anyone?
A garage in Melbourne told me you must fit both restrictors in to drop the boost. It's news to me, I thought there was only one olive. But I have two in the bag so it must go somewhere?
I wonder how may people have only removed / installed one?
I have refitted the restrictor before.. no problem. Not sure what they mean.
I don't know where the second one is fitted sorry.
no need to apologise for some of the smart ass comments i received guys...
I FORGIVE YOU!
Airchair experts, who havent actually done what they are claiming thats what it is :)
dont worry thats life :)
I FORGIVE YOU!
If you keep at it enough, you'll have the 'setbacks' etc, but eventually answers come..... :P
If you keep at it enough, you'll have the 'setbacks' etc, but eventually answers come..... :D
yeah, however next time im just not going to say anything and let em think what they want.. then everybody is happy :D
I can't admit to studying the stock solenoid system too much (it's one of the first things to get the bin :()
But I think that some people in this thread are mistaking the 3-port setup of most aftermarket EBCs and the 2-port setup of the stock solenoids :(
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
