Ok so i got a highmount TD-06 set up on my R32 and was jsut wondering if anyone else had the same turbo, what mods do they have and what is the turbo good for at the end of the day.
With the right mods to the Rb20 what do you recon the over all figure i could get out of it without spending thousands on a complete rebuild and what rpm are you making boost???
Cheers B
https://www.sau.com.au/forums/topic/88536-td-06/
i have one, but ive got a blown motor, so havent dynoed it, best person to talk to is ROY, they are a great turbo for the rb20 and can make aroung 250rwkw with supporting mods. im hoping to get as close to 300rwkw with mine, but i have a worked engine. I may end up geting T67 to replace my TD06.
https://www.sau.com.au/forums/topic/88536-td-06/#findComment-1598545
have currently bolted one to a rb20 with an 8cm rear housing....in terms of mods, nothing major just front mount pod exhaust made 230rwkw and actually ran 12.2 last night at WSID (congrats tim)..... my old setup was rb25 with cams etc etc made 265rwkw with a 12cm rear housing......in all truth to see a 20g reach 300rwkw is a big task....however the 25g/t67 will see you well over 300rwkw, however on a rb20 you'll lose alot down low.
What really freaked me out was when we put a 700hp garrett gt turbo on a rb20 with a stock motor with frount mount and exhaust and boost, it made 266rwkw!!
https://www.sau.com.au/forums/topic/88536-td-06/#findComment-1598721
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
