Sorry Guys i have done a million searches on the site but cant seem to find any info. How can i tell if my oil pump is on its way.
Comparing my Oil pressure gauge to a mates car whos is identical to mine on idle both our cars side on 3 on the oil pressure gauges. When you accelerate in either car mine struggles to make it to about way on the gauge were his 1 climbs.
Now i have thought about the sender to the unit may be faulty but i would really like to test the engine oil pressure rather haveing to go upon what the gauges says.
Could the problem be my oil pump not pushing up enuf oil?
BTW the car is a R33 S1 GTST
Front mount, exhaust and filter are the only mods for now
https://www.sau.com.au/forums/topic/88543-oil-pump-pressure/
You're right, there are a million threads on this. I just replaced the sender unit on my RB26. The unit is located immediately to the rear of the oil filter. I am assuming the location is the same on an RB25. You can (With the right spanners) remove the sender unit & attach a mechanical gauge. Rev it to the rpm's suggested in the engine manual & read the figure.
The fault you describe is the same fault as my old sender unit.
Ninety something percent of the time the sender unit is faulty, not the oil pump. For peace of mind, it is best to cough up the $200 for a new sender. This has the added bonus of making the car easier to sell. Hard to convince a prospective buyer that the engine is ok when it is reading 0 psi pressire. Think of it as an investment.....
thanks for that dude, ill give it a try this weekend but this this car wont be sold as i will be going for a GTR in the near future but the misses loves the car and wants it as her lil Drifter. lol. I guess that means her Echo becomes her Weekend car. LOL.
Definately ill give it a go this weekend
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
