(Use this as a guide for new threads. Delete and/or copy the fields as needed - dont forget to add your location in the description field above. Delete this message)
Item:
Item Condition:
Reason for Selling:
Price and Payment Conditions:
Extra Info:
Contact Details:
EDITED ALL PRICES DROPED!!!!!
Here are good tyres i have had lying around need to clean up
2X 245/40/17 Continental Conti Sport 90% tread = $180 the pair
2X 225/50/16 Continental Conti Sport (Burnouts) = $10 the pair
1X 225/40/18 Michelin Pilot Sport 90% = $90
1X 225/55/16 Continental Conti Sport 85% slighty worn inner edge = $30
1X 235/35/19 Continental 70% = $100
1X 215/45/17 Bridgestone Potenza 99% = $80
1X 205/50/17 Bridgestone Potenza 99% = $80
1X 205/40/17 Dunlop SP3000a 99% = $80
THIS MUST GO!!!!!!!!!!!!! PM ME
thanks all must go
Edited by SXC_R33
https://www.sau.com.au/forums/topic/88604-tyres-4-salemust-go-cheap/
OK no being rude but serious offers only not 100 for two immac tyres??? that are worth big bucks new, sorry mate wont let it go for that much !!!
Hey mate.
I'll give you $100 for the pair of 17" continentals.  Send me a message when you want me to pick them up and where to come to.
Cheers,
Mick.
    • Man that dinner was such a long time ago....2010! I would only replace the rubber coolant lines with silicone these days; cheap, readily available and will last for ever. You will need new hose clamps though eg https://justjap.com/products/cooling-pro-silicone-engine-heater-hose-set-black-nissan-r32-gtr-rb26dett
    • I wouldn't look too hard at what they did with the R32 GTR in endurance racing in Australia... Lots of things weren't actually available from the factory in the way those cars ran them... Japan also followed what Fred Gibson was doing here with some of there endurance cars in Japan... Australia is also the reason for things like the Brembo brakes, and the change in the gearbox... And quite a few other tricks they used to pull. There's a few other SAU peeps still on these forums that will have heard the stories direct from Alan Heaphy, Fred Gibson, and Jim Richards when we were lucky enough to have a great dinner with them
    • For all the talk of "these parts are junk" I generally recommend OEM because it's really not as bad as claimed. I have never seen or heard of a case like the N63 where the oil returns completely clog with coked oil for example in ~10 years or less. Would it be nice if it were a straighter path? I guess, but most modern cars use a scavenge pump instead of a pure gravity return. Also the factory lines that would be relatively simple to convert to braided are generally speaking hardlines from the factory. I would consider braided line to be a regression, not an improvement. It's also been engineered such that all the hardlines have appropriate strain relief where needed. There's absolutely room for improvement, for example the HKS advantage heritage intake piping shows just how much can be done to make the turbos fight each other less in OEM twin turbo configuration and reduce compressor surge but it's rarely a simple/straightforward process. I recommend looking at what the group A/N1 cars did, generally speaking the changes they made were necessary and proven in endurance racing.
    • Yes, multi relays needed, and possibly a diode. I'm not actually going to think about it though.
