Evo Ix
Mr. Oizo
 Share
So who'd buy an evo with wind-up windows and no radio? Is it a weight saving measure?
And where are the Recaro buckets?
Its like the N1 GTR, its the cut down "homologated" version the rally cars are/were based on. Power windows, radio, air conditioning (I believe the RS does have 'climate control' though) are all pretty much useless in a car that is sold with the intentions of being the basis of a rally car. That said though, people do by the RS because its cheaper, and/or they dont mind using 10 seconds of muscle to wind down the window.
That said, I have a test drive of the Evo IX on Friday afternoon... hoping I dont turn it into something resembling that :D
Im sure alot of parts could still be used from that car, considering its almost new.
Just off the top of my head,
- Seats
- Springs/Shocks/Bushings
- A rim? :)
- Some parts of the dash
- Aircond control panel
- Dash cluster
- Sway Bars
Im sure theres more little pieces here and there he/she could salvage some money for..
And did the steering crumple or was made to crumple to remove the driver?
Curious.. :P
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
