Finally the budget allows for a turbo back exhaust to be fitted to the 33. I was just about to buy a nice looking Trust stainless catback system, then chuck on a front pipe etc, when a mate told me it would be cheaper to go to an exhaust shop and just get the full thing made up. It will probaly work out cheaper as well as allowing me to choose the exact muffler i want and also the angle it points out at the back, the only problem is will a custom exhaust be less flowing, due to welds???
https://www.sau.com.au/forums/topic/88622-custom-vs-brand-exhausts/
Beware getting the local bloke to do it unless he can show you dyno figures from one he's done before for a similar car. The second hand ones you see at wreckers etc are really cheap and if it's a name brand Jap thing like HKS or Trust you can usually rest assured that it'll work OK. Custom jobs, if they're any good, will usually cost $$$
said it once and ill say it again. the key
#1 get a 3" split dump from BATMBL on the forums - $410 delivered
#2 take pipe to exhaust shop
#3 ask how much to fit #2 and supply 3" hiflow cat and 3" exhaust
id say resonable price for #3 would be $900
most jap kits are $1300 odd unfitted, and are cat back
Pfft sif custom jobs = more $$. I'm sick of the majority of people thinking this. It'd work out to be cheaper than what you'd payed for a full jap system and the thing is it'll work out to be whatever you need it to be. A full jap system shipped from Japan will cost you a stupidly high price, and thats not even if you get rorted by customs yet.
You can get a decent full 3" exhaust brand such as X-Force at local exhaust shops for around $1100 to $1200 fitted. Spend the savings from Jap brand for mods that give you good gains (bleed valves, ecu/piggy backs) And I don't believe there are big power difference with Jap brand, other than sounds.
I'd also look at buying a Magic (see Magic Performance on NissanSilvia) or Catco (see BATBML) cat before hand.
By the way, cat-back Japanese exhausts have fallen a lot in price. You can get the Trust Power Extreme II (or whatever its called) full stainless cat-back for about $800, give or take a few bucks. More expensive brands like Fujitsubo are about the $1000 mark.
Rofl, people over-price JDM exhuast system;
Most of them cost $400 or so brandnew (catback only) then add the price for front and dump pipe looking at like $1000 for full exhuast system then add some shipping maybe around $1300-$1500
And it doesnt take a rocket sciecntest to install an exhuast all u need is a jack and some time
I had to get a custom turbo to cat pipe made up as my car is not a skyline and there was nothing available off the shelf.
I got it done at liverpool exhaust and it was $330. if it was a skyline it would have been $300.
It is a top job. excellent welds and no kinks anywhere. very well made.
I would not do it for a skyline as there is just so much stuff available.
the x-force stuff is OK but the split dump joins to close to the turbo. you would be better off with the one from batmbl. but it is twice the price. but you get what you pay for. his is the best.
you should also get the cat from him.
as for the rest of the system it's up to what you can find secondhand. or you could just buy a cheap x-force catback.
all up you will be spending $1100 plus fitting for a well designed properly flowing system.
Just buy an xforce turbo back exhaust from ebay for $650 and fit it yourself. Thats what I did and I almost gurantee that it performs as well as any of the name brand jap kits from the cat back.
If you want to spend a bit more just get a good quality split dump pipe and high flow cat (although the XForce cat is not to bad). Try getting a custom split dump pipe made up - it will cost you an arm and a leg.
My 2c
custom advantages:
- brand new pipes and mufflers
- to your car's custom specificiation
- you can make the best combo for your car
- cheaper
- hangs high up as its custom made
custom disadvantages:
- no proven power gain
jap-brand advantages:
- tried and tested
jap-brand disadvantages:
- hang very low
- old mufflers that have lost their baffle
- old pipes that are beginning to show signs of ageing
- expensive
jap brands are just not worth it, as you are getting a mass-produced product that never fits as nice as a custom job and costs twice as much for something that is getting old
custom jobs are NEW and CHEAP and CUSTOM to your specific noise and power requirements..
i swear by the custom job
Warren.
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
